5. N Scale bedroom Layout - second rail ring
A Forum that is covering a build of a South African N Gauge layout by Fidel Naidoo.
Fidel Naidoo
Post by Fidel Naidoo »
I hope it was a happy festive season for all!!
I got an entire box of Peco flexible track from Father Christmas. A most welcome gift.
The biggest lesson I have learnt from this exercise so far, is that you mustn't be scared to pull down what isn't working, which I have done several times on the layout. Every single one of my rolling stock must be able to travel on every part of the layout.
I've also learnt that I can't do without a Dremel, and fierce skills of soldering rail.
But I don't have a clue how to make photos smaller without them pixellating and loosing detail.
Anyone got advice?
The bridge is gone. I had to smooth out curves still even further, and cut the polystyrene risers away to flatten their curvature, and lost the adhoc bridge in the process.<br />Obviously, the start of the riser had to be pulled forward to keep the grade steady.
The switchwork and de-couplers for the rural station are done.<br />Just have to wait a few weeks to get funds for some more point motors.
The difficult locomotives are kept on standby now, both 4-8-4's, to test all joins and curves.
and the block control unit is working exceptionally well. I can't wait to be in a position to engineer semaphores into the equation.
arnocronje
Re: N Scale bedroom Layout - second rail ring
Post by arnocronje »
Hi Fidel, not sure how you resize your pictures, but with my limited knowledge it will be hard to resize without losing detail when you zoom. I always resize to "web large". Suggest if someone needs full size pictures, they can e-mail you and you can send it seperately. Good job on the layout. regards Arno
Fidel,
What are you using to resize your pictures?
Fidel Naidoo
Arno,Thanks. This forum has a very strict 200kb limit on posted pictures, so I reckon that 'Web Large' may exceed that.
Kevin, I use my girlfriend's latest model Samsung camera, with something like 14 million pixels. The smallest I can set on the camera is 1024 X 768, but still much more cropping and resizing has to happen. I resize in Windows paint, and save as JPG. Do you reckon a different package like photoshop would work better?
If you have something like Photoshop already, yes.
First reduce size - use the pixel option eg 800 by 600. There are different reduction parameters in terms of pixel handling - try each one.
Then edit and save. The packages will let you save to a maximum of in k.
If you do not have a program you can try the Gimp (free) or go out and get Paint Shop PRO - Incredible Connection or buy off the Internet - R 799.00. Highly reccomended, easy to use and powerful.
I run Linux on my computer so I use the Gimp and I find it very good.
Fidel Naidoo
Kevin,
Thanks. I got Gimp now, and I'll see how it works the next time I take photos.
arnocronje
hi fidel, I see you got plenty advise on the resizing of the photo's, so I am sure you will find the best solution. For what it is worth, the one that I am using is simply MS Office 2010. Right click on the photo and choose the option to open with "MS Office", which then allows you to easily resize. Cheers, Arno
Arno - a good tip there. Thanks.
Return to “N Scale Entire Bedroom Layout”
