Interesting that a shunting loco has such a big tender. One would have thought it could be built with a small tender as presumably it would never be far from a water column. Were these the original tenders or were they added later? Or did the heavy tender have some other function, eg to assist with braking if they were shunting wagons without the vacuum coupled through?
John from what I can remember the S2's have always looked like that. I always begged my father on a Sunday afternoon to drive into the docks, not to see the ships but to see the Steam Loco's. Driving down Table Bay Boulevard my Easgle eyes were always looking for the signs of steam. In those days I did not know one from the other but it was a steam loco. When the Class 36's arrived it did not just seem the same.
My question got answered by some of the old hands at Capital Park today. The tender is original. It's about the same size as a Class 24 tender, but it has the cut-away sides to allow good rear vision for the crew. I'm told that they were built to shunt "down at the docks" (which docks?) where there were few water columns, and also that they were used very intensively and had no time to waste taking water.
Here's a couple of harbour shunt pics from July 1981, plus a grab shot from 1978. These are from slides that weren't in great shape; I had to photoshop them, still not great. Nice memories though.
An S1 idling in the harbour.
CT Harbour shunt (4).jpg (53.16 KiB) Viewed 9058 times
This S1 was shunting old boxcars out of the power station, blocking the road in the process. Today, the train, the line, the power station and the building in the background are all gone. June 1978.
CT Harbour shunt (6).jpg (57.67 KiB) Viewed 9058 times
This is actually Paarden Eiland sheds, not the harbour, but same enormous rock behind it!
CT Harbour shunt (5).jpg (57.39 KiB) Viewed 9058 times
By Custom House (is that the bldg name?)
CT Harbour shunt (3).jpg (112.38 KiB) Viewed 9058 times
Harbour shunt July/Aug 1981
CT Harbour shunt (1).jpg (57.08 KiB) Viewed 9058 times
They were horrible locomotives to fire. The boiler was small, and you were forever putting fire ion, then the boiler pressure rises, put on the injectors then the pressure falls. You had to fire them with the blower on . They had a speed restriction plate fitted on the boiler above the flame plate saying maximum speed 25kph.
Remember they are 0-8-0.
Pretoria had a regular one for the Blue Train shunt and it was painted blue. Probably the first ever Blue S2.
I did not know that they were still working in 1981. I thought that the Class 36's had taken over by then. Good to see. Nathan apperantly they could go backwards faster because of the lack of leading wheels.
S2s were one of three SAR steam classes to have tenders longer than the loco. I'll leave you to work which the other two were.
Holland suggests that after Krupp won the contract to build them they found it couldn't be done within the specified weight, and thus there had too be a drastic rethink and a reduction in boiler size. Whatever happened I believe the boilers that were fitted are a lengthened version of the NG/G16 boiler.
I don't remember too many problems with them at PE, though as Nathan says the smallness of the boiler did mean there was very little storage capacity and therefore you had to be on the ball. It is certainly true that they were rough riders at speed, as I found on a light engine trip back from Uitenhage shops to Sydenham.
I seem to remember a photo in one of Dusty's books of a line of S2s all coupled together on their way to Paarden Island shed for servicing from the docks.
Aidan , they used to line up like that in the docks as well. You could see about ten or 15 of them all sizzling away in front of the then newly built customs house.
