3117's mechanical stoker motor under repair and maintenance
- Gabor Kovacs
- Friends of The Rail
With the recent trips, it was found that 3117's mechanical stoker motor was wasting large amount of oil while in use.
Robert Dadford, decided to remove the stoker motor for repairs and maintenance.
During the past week Robert and Spikkels un-done and removed all plumbing and coupled the universal joint between the motor and the stoker drive staft.
Yesterday, Saturday, 13th March 2010 - I assisted Robert to remove the stoker motor and started with cleaning the motor and checked for other faults. Here are a few pics.
Photos by Gabor Kovacs - Saturday, 13th March 2010
- one of the brass plates fitted to the soker motor
- IMG_0027 - Copy.JPG (124.63 KiB) Viewed 11235 times
- Internal piston rods, and valve rods of a dirty mechanical stoker
- IMG_0025 - Copy.JPG (109.58 KiB) Viewed 11236 times
- prior to the cleaning of tender stoker housing
- IMG_0026 - Copy.JPG (123.97 KiB) Viewed 11235 times
- cleaned stoker motor
- IMG_0029 - Copy.JPG (85.4 KiB) Viewed 11233 times
- A clean stoker motor, while tender stoker housing being cleaned
- IMG_0028 - Copy.JPG (81.21 KiB) Viewed 11233 times
Re: 3117's mechanical stoker motor under repair and maintenance
Thanks, Gabor. The stoker motor doesn't usually see the light of day and I can't say I've ever seen one in its full glory before. Usually you just get to see a bit of it when you open the flap on the side of the tender to check the oil.
I assume the Stoker Motor runs on steam. Can one of the experts give us a rundown on how it works and operates.
Thanks
Thanks
Aidan McCarthy
The stoker motor itself itself has two steam cylinders, these are the two round parts at the one end of the stoker motor. These drive a crank shaft at the other end of the motor, this is encased and runs in oil. A drive is taken from the motor by a long shaft to a reduction gear box as the back of the coal space of the tender. The output of this gearbox drive the stoker screw which feeds the coal from the tender to the firebox.
Hope this make it a bit clearer how it works
Just to prove that Gabby actually did clean, wash and bathe this little steam stoker engine himself.
- Note that Gabby is never content to allow the locos to outdo him in the area of smoking.
- js800_IMG00065-20100313-1057.jpg (118.02 KiB) Viewed 11108 times
Wonderfull. Now we should be ready to roll them in on the next trip and be secure in the knowledge that the motor is fixed. Mind you, it will still be fun to hand fir the loco. Well done guys who fixed this up.
- Andreas Umnus
Also I have to say Thank you for showing us a stoker motor and the explanation of how it works.
