Train-smi.com - file name sacor1-x.zip
South African passenger wagon model corrections by Cobus Prinsloo. These basically correct the appearence of the various coaches - the connecting corridor gaps between coaches are removed.
An extensive pack, including updates for.....
SA Union Coaches (you will have folder called SA_Union_Limited if these are installed).
ROVOS Coaches (you will have folder called ROVOS if these are installed).
SAR Water Heaters - red, oange and blue versions (you will have folder called SAR Water Heater if these are installed).
SAR Blue Train Staff Coaches (you will have folder called SAR_Blue-Staff if these are installed).
SAR Guards Van (you will have folder called SAR_KP-1 if these are installed).
SAR COaches New Colours (you will have folder called SAR_PAX_New if these are installed).
SAR Coaches Old Colours (you will have folder called SAR_PAX_Old if these are installed).
SAR Coaches Orange Express (you will have folder called SAR_PAX_Orange_Express if these are installed).
SAR Guards Van Autocarrier (you will have folder called \SAR_SCJ-8 Auto if these are installed).
SAR Shozaloza Myel Coaches(you will have folder called SAR_Shozaloza_Myel if these are installed).
Be careful with the installation if you do not have all the above installed, as the installer will create the folders above which could lead to MSTS reporting errors.
To install safely rather direct the installer to you desktop, then select just the files you need (the .wag and .sd files) and then over-write the files in the MSTS/TRAINSET directory as required.
New SAR coach upgrades/fixes
