3117 - illumination
3117 - illumination
Underfloor lighting to enable the fireman to see the injector is working in poor visibility. This was fitted by Robert Dadford. Two more such lights have been installed either side of the valve gear of the 15F 3117
Photo by Nathan Berelowitz January 2008
15F3117progressjan2008locos 011.jpg (33.95 KiB) Viewed 8193 times
Re: 3117 - illumination
Robert has now fitted lights under the front end - useful for servicing the loco at night
Driver's side<br /><br />Photo by John Ashworth 09/02/08
Driver's side
Fireman's side<br /><br />Photo by John Ashworth 09/02/08
Fireman's side
Another photo by Nathan
Underfloor lighting fitted on 3117 near the valve gear will enable the driver to do some early morning greasing and oiling. Robert Dadford and his assistant Louie have been hard at work fitting the electrics on this loco, additional to the original specifications. <br /><br />Photo by Nathan Berelowitz 09/02/08
Capital Park weekendworker Feb2008 023.jpg (45.8 KiB) Viewed 8148 times
Nathan wrote:The soft glow of the underfloor lighting fitted to 3117 will help the
Footplate crew to check on the injector operations in poor lighting
conditions. Ideal for a late firelight! Robert Dadford fitted this and a
second light, near the front end motion of the locomotive.
Working under its own steam at last! <br /><br />Photo by Nathan Berelowitz 04/10/08
3117first light up 4sept2008 007.jpg (46.63 KiB) Viewed 8090 times
Andreas Umnus
Post by Andreas Umnus »
This is a thing I was never aware about.
It is good that you have good ideas.
