Cullinan Trip: 13th September 2014
This was a private charter. Both our locos are still down, so this time Reefsteamers kindly lent us their 12AR no 1535 with their own footplate crew.
Unfortunately this trip was terminated at Koedespoort due to rioting on the line at Mamelodi, and the passengers had to proceed by bus.
Photos by John Ashworth, 13th September 2014
Reefsteamer's 12AR no 1535 stands at Hermanstad in the early morning light as chickens scratch the ground.
Guard Gabor walks alongside the tender as the loco sets back to couple on.
1535 couples onto the load in the platform in order to remove the DZ wagon and four coaches.
As 1535 drops off a DZ wagon and a suburban coach it could almost be a mixed train from the old days. Note the water tank behind the tender.
A chance to add some oil.
A view across the Hermanstad site. The empty space here is where the inspection pit and shed will eventually be built.
The passengers pose by the old 15F and 24.
The theme appears to be Wild West.
Guard Gabor does the vacuum test at the rear of the train before departure.
The stop board marks the interface between FOTR's private siding and the TFR Hercules yard.
Guard Gabor walks alongside the rear vehicle directing the driver by radio as the train sets back to the stop board. The Hercules shunt cars are visible on the right.
The signal has cleared and the train sets back out of Hercules yard into Hercules Station.
The train curves around as it crosses the Metro lines.
Still setting back.
Still setting back.
1535 recedes into the distance.
Having set back into Hercules Station, 1535 stands awaiting the signal to depart.
The signal has cleared and 1535 steams forward out of Hercules Station.
Philip Martin
Re: Cullinan Trip: 13th September 2014
Post by Philip Martin »
Wild West Theme: but was the driver wearing a ten gallon hat (like this one on Conrail in New Jersey?)
No, I'm afraid Shaun was wearing a flat cap!
Philip Martin
Here's a better copy of the Conrail engineer in the sombrero.
Philip Martin
Those chickens standing in front of Susan- are they scratching up diamonds in the dirt?
