UK floods
UK floods
A few pictures of flooded railways in the UK in July 2007.
These were taken from free public news websites - we can remove if the copyright holders object.
- Flooding in the Moreton in Marsh area, July 2007
- flood Cotswold1s.jpg (20.2 KiB) Viewed 7932 times
- flood Cotswold2s.jpg (24.17 KiB) Viewed 7931 times
- Flooding at Newbury Station, July 2007
- flood newbury_station_470_470x300.jpg (30.89 KiB) Viewed 7933 times
- flood_newbury station2_470x313.jpg (38.25 KiB) Viewed 7934 times
- Flooding at Aldermaston Station, July 2007
- flood_aldermaston station_470x300.jpg (33.87 KiB) Viewed 7933 times
Yet more UK flooding pictures, these ones from the North Norfolk Railway on 2nd August 2006.
http://www.nnrailway.co.uk
- Sheringham Station, 02/08/06
- sheringham flood_east 20060802.jpg (27.58 KiB) Viewed 7905 times
- sheringham flood_j15 20060802.jpg (33.93 KiB) Viewed 7904 times
- sheringham flood_west 20060802.jpg (25.56 KiB) Viewed 7905 times
Off topic, but I couldn't resist these two bus pictures.
http://lower-edmonton.co.uk/images/scans/leip/49.jpg and http://lower-edmonton.co.uk/images/scans/leip/27.jpg
- The Hertford Road flooded by St Edmunds School in July 1956 - Lower Edmonton. The bus is probably an RT
- edmonton flood 1956 27.jpg (45.48 KiB) Viewed 7901 times
- A 679 trolleybus negotiating a flooded Fore Street in 1949 with the wooden road blocks floating to the surface
- trolley edmonton flood 1949.jpg (35.35 KiB) Viewed 7902 times
A different type of flooding - the sea breaks over railway lines along the UK coast.
- Volks Electric Railway, Brighton
- volks.jpg (80.61 KiB) Viewed 7898 times
- Waves batter a train as it passes along the coastal railway line at Dawlish in Devon, south west England. 27 Oct 2004 REUTERS/Toby Melville
- dawlish X9000 400200410 28e0as 00001.jpg (63.56 KiB) Viewed 7897 times
- Dawlish
- devon_railway.jpg (28.08 KiB) Viewed 7898 times
And now back to July 2007
- Photo taken from the window of the 1500 Birmingham to Euston train, July 2007
- birm-euston flood jul07.jpg (44.67 KiB) Viewed 7895 times
- The Severn Valley Railway, July 2007
- svr damage 2007 pa203b.jpg (23.5 KiB) Viewed 7895 times
- The London Underground, July 2007
- tubeG2007_468x325.jpg (42.71 KiB) Viewed 7894 times
- Water cascaded down the steps at Charing Cross underground station, July 2007
- underground ST2007_468x616.jpg (82.49 KiB) Viewed 7893 times
- Newbury Station again, July 2007
- newbury station_s.jpg (37.99 KiB) Viewed 7894 times
- Cancelled, July 2007
- cancelled_train203.gif (28.91 KiB) Viewed 7895 times
And a couple more...
- First Great Western High Speed Train (HST) with the water just about at rail level, at a stand at a signal close to the Alstone Lane level crossing in Cheltenham, July 2007
- cheltenham fb_os.jpg (35.02 KiB) Viewed 7886 times
- Banbury Station, July 2007
- flood banbury d8.jpg (110.51 KiB) Viewed 7885 times
And I suppose a leaking aqueduct could cause a flood of sorts?
When this railway was built circa 1917 it was obviously felt that it was important that this river continued on its path. In modern times it now leaks quite well down the left hand column in the picture.
http://www.geograph.org.uk/photo/160431
- Leaky Aqueduct over disused railway near to Llan Ffestiniog, Gwynedd, Wales.
Copyright Barry Hunter - aqueduct 160431_cd6e4d78.jpg (78.74 KiB) Viewed 7884 times
And back to past floods - the main line to Cardiff in the winter of 1965.
Photos from http://www.alangeorge.co.uk/pentrebachStation.htm
- The main line to Cardiff in the winter of 1965
Anthony Phillips - Pentrebach_Railway Flood_2.JPG (62.23 KiB) Viewed 7866 times
Anthony Phillips - Pentrebach_Railway Flood_1_small.JPG (24.09 KiB) Viewed 7865 times
Huge quantities of bottled water has been delivered to people whose tap water has been cut off or has become undrinkable, and some of this has been delivered by train.
These pictures are from http://www.petertandy.co.uk/Recentpics.html and have the following text with them:
The dreadful weather of the weekend on 21 July 2007 resulted in large tracts of Gloucestershire being inundated with flood water. One of the worst consequences of this for the residents of Tewkesbury, near Ashchurch, was the failure of their water supply due to a plant treating drinking water being flooded. Tesco and EWS made rapid arrangements to help out by ferrying large quantities of bottled from Mossend to the MOD depot, via Bescot. This picture shows 66207 arriving at Ashchurch with 6Z12, the 07.30 from Bescot. The water, carried on pallets in the ferrywagons, will be offloaded by fork-lift truck and then taken by road the short distance into Tewkesbury. The train will run beyond the exchange sidings to the south of the roadbridge upon which I was standing, reverse into the sidings and then propel its train along the branch, formerly the line to Evesham and Redditch, visible on the right of the picture.
Here is 66207 after the procedure I outlined above has taken place. The branch has 2 footpaths crossing it and a shunter walked alongside the track in front of the first wagon to ensure that no pedestrians were in danger, the man being in radio contact with the driver at all times. This train seems to have required some fairly complex manning arrangements in that a Didcot driver appears to have come here by road to relieve the Bescot man, who would not sign the branch, the latter returning to the West Midlands by road. Another crew came, presumably from Worcester, to unlock the ground frame allowing access to the the exchange sidings. All this would have to happen again, but in reverse when the train leaves Ashchurch for Bescot in the late afternoon when it runs to Gloucester to run round, there being no egress to the north for trains leaving the exchange sidings.
The sun had shone pretty much all morning up to the point when 66207 with 6Z12 appeared in the distance and went into the down loop at Ashchurch. A Voyager, a 170 and a 158 passed in sun but clouds built up just as the train of bottled water was given the road out of the loop onto the main line. The only glimmer of sun came as it reversed around the curve on the line towards the MOD facility. Here is 6Z12 about to disappear into the undergrowth surrounding the short branch.
- 66207 arriving at Ashchurch with 6Z12, the 07.30 from Bescot, carrying bottled water
- 66207_6H20(3)_Ashchurch_280s.jpg (36.26 KiB) Viewed 7837 times
- 66207_6H20(2)_Ashchurch_280s.jpg (35.43 KiB) Viewed 7837 times
- 66207_6H20_Ashchurch_280707s.jpg (23.44 KiB) Viewed 7837 times
