A Portrait of Strength
Members can post FOTR related pictures of other FOTR equipment here - screenshots or photographs - 800x600 pixels. Maximum size 130k. They will be pruned after 90 days. If you want to keep them for later, save them to your hard drive!
Post by Tom Macrery »
Size, mass, strength necessary to transmit the power and haul the goods.
A massive knuckle helps the work to get done.
Re: A Portrait of Strength
The couplers always fascinate me. If you think of the strain on it as it holds the coaches together safely and over all gradients. Amazing. The FOTR logo has the buffers clasped in a hand shake!
John Fellows
Post by John Fellows »
When I worked at DB Shenker, we built a fleet of bogie ballast wagons, which involved fitting this type of knuckle coupler. These weighed an absolute TON,and were very scary and awkward to handle.
One careless move and you would certainly lose some fingers !!
Return to “FOTR Miscellaneous Equipment”
