Nathan wrote:Viewed from the inspection pit, one can clearly see the ahspan slide that is
operated by a pull rod in the cab floor. The slide is opened during the fire
cleaning period and the dampened ashes and clinkers, will make their way
into the ashpit. This important fixture must always be closed, as live coals
can fall out and cause lineside fires, whilst the train is on the move.
Where does all the ash go?
Members can post FOTR related pictures of other FOTR equipment here - screenshots or photographs - 800x600 pixels. Maximum size 130k. They will be pruned after 90 days. If you want to keep them for later, save them to your hard drive!
- Photo by Nathan Berelowitz 12 April 2009
- CapparkHercules 12 April2009 005.jpg (54.01 KiB) Viewed 6991 times
Re: Where does all the ash go?
It is always amazing how impressive all the workings under a steam loco look, when down in the inspection pit!
Return to “FOTR Miscellaneous Equipment”
