Using Avatars
Need help using this site? Check here first!
Your question may already have been answered here! If not, ask in the "FOTR Forum Help" below.
Using Avatars
The Avatar feature has been enabled.
Avatars are generally small, unique images a user can associate with themselves (see the picture on the right).
The images are small - the size should be not greater then 100 pixels by 100 pixels, 10kb in size.
To load an Avatar go to your profile (User Control Panel) and then load via the profile section.
See the pdf file below if you are uncertain.....
avatar.pdf
(229.08 KiB) Downloaded 393 times
Return to “This Forum - Frequently Asked Questions”
