3020 and the diesels
This morning 3020 was moved onto the adjacent "through" road to be fuelled. Later in the day it seems a procession of diesels needed to make use of this road, so 3020 was shunted aside. Here is a series of photos of the various movements, by John Ashworth, Nairobi, 28/04/10.
- 8720 waits to do the honours
- 3020_and_diesels_IMG_2822.JPG (64.09 KiB) Viewed 2146 times
- 8720 approaches the shed
- 3020_and_diesels_IMG_2824.JPG (68.94 KiB) Viewed 2146 times
- Nearly there...
- 3020_and_diesels_IMG_2825.JPG (59.77 KiB) Viewed 2146 times
- "Hokkay!" in South African railway parlance - "Stop!" to anyone else
- 3020_and_diesels_IMG_2826.JPG (60.1 KiB) Viewed 2146 times
- Checking the coupling
- 3020_and_diesels_IMG_2827.JPG (48.84 KiB) Viewed 2146 times
- Setting back
- 3020_and_diesels_IMG_2830.JPG (67.55 KiB) Viewed 2146 times
- About to uncouple
- 3020_and_diesels_IMG_2832.JPG (71.97 KiB) Viewed 2146 times
- 3020 basks in the sun
- 3020_and_diesels_IMG_2834.JPG (77.23 KiB) Viewed 2146 times
- 8720 now runs past 3020
- 3020_and_diesels_IMG_2835.JPG (70.38 KiB) Viewed 2146 times
- 8720 on the traverser
- 3020_and_diesels_IMG_2836.JPG (66.29 KiB) Viewed 2146 times
- The traverser begins to move
- 3020_and_diesels_IMG_2837.JPG (66.03 KiB) Viewed 2146 times
- 8720 sets back off the traverser
- 3020_and_diesels_IMG_2838.JPG (53.74 KiB) Viewed 2146 times
- Almost off
- 3020_and_diesels_IMG_2839.JPG (61.9 KiB) Viewed 2146 times
- 8720 sets back into the workshop
- 3020_and_diesels_IMG_2840.JPG (55.89 KiB) Viewed 2146 times
- 9326 runs through the steam shed, passing 2409
- 3020_IMG_2841.JPG (56.91 KiB) Viewed 2146 times
- 9326 trundles onto the traverser...
- 3020_IMG_2842.JPG (71.46 KiB) Viewed 2146 times
- ...and trundles off on the other side, a couple of roads to the right
- 3020_IMG_2843.JPG (65.14 KiB) Viewed 2146 times
- Andreas Umnus
Re: 3020 and the diesels
If you compare picture 7 and 9, the 8720 looks very wide beneath the 3020 but if you see the 8720 behind the 3020 both locos have the same width?
Good illusion.
Good illusion.
The short nose at the cab end of a class 87 is the full width of the loco, whereas the long engine compartment behind the cab is less than the full width, with a walkway on each side. Maybe that contributes to the illusion?
