Overshadowed a bit by 3020's wedding performance on 1st May 2010, here are a few more photos of her first steaming, a trial run on 23rd April 2010.
Photos by Bert van 't Oever
3020 first steaming - 3
- 3020 on shed
- nairobi218.JPG (82.29 KiB) Viewed 2703 times
- Interesting faces 1 - Fireman James
- nairobi250.JPG (43.54 KiB) Viewed 2703 times
- Interesting faces 2 - Driver Benjamin
- nairobi251.JPG (47.68 KiB) Viewed 2703 times
- Driver Benjamin
- nairobi252.JPG (94.42 KiB) Viewed 2703 times
- There was a fair bit of shunting going on that day.
- nairobi275.JPG (122.63 KiB) Viewed 2703 times
- Fireman James
- nairobi281.JPG (66.44 KiB) Viewed 2703 times
- John learns to fire an oil-burner
- nairobi293.JPG (74.84 KiB) Viewed 2703 times
- Benjamin sets back
- nairobi295.JPG (66.19 KiB) Viewed 2703 times
- View from the footplate
- nairobi297.JPG (40.41 KiB) Viewed 2703 times
- 3020
- nairobi316.JPG (104.61 KiB) Viewed 2703 times
- 3020 stands in the sun, while the Managing Directors of Kenya Railways and Rift Valley Railways inspect her
- nairobi317.JPG (111.1 KiB) Viewed 2703 times
- Gabor Kovacs
- Friends of The Rail
Re: 3020 first steaming - 3
Hi John!
Some really nice pictures you have shared with us all. You surly must be enjoying the steam stuff in Kenya!
John, what is the gray box with handle and red skirt next to the driver in pic 4? I am guessing air-brake control?
Correct, Steve, that's the air brake. Kenya Railways has used air brakes since very early on, reportedly due to the high altitude which reduces the efficiency of vacuum brakes - there is some discussion of this on the forum here. The air brakes operate on the train, not the loco (I haven't confirmed yet whether they operate on the tender, but the driver doesn't operate the air brakes at all when travelling light locomotive without a train).
There's also a steam brake which operates on the loco itself. The handle (with ratchet) can be seen in the same position, roughly, where the regulator is on a South African 19D or 24. The regulator can be seen just to the left of the air pressure gauge.
