Today 2409 moved under her own steam. It was rather too dark to get any decent photos with my small camera.
Photos by John Ashworth, Nairobi, 16th May 2011
Kenya Steam Safari Preparations 7: 2409 in steam
- 2409 stands in the sun with just a faint haze of smoke beginning to appear from her chimney
- steam_safari_2409_IMG_4480.JPG (74.09 KiB) Viewed 8356 times
- At some point in the past the buffer beam had been painted black. This morning Kevin painted it red again
- steam_safari_2409_IMG_4479.JPG (84.85 KiB) Viewed 8356 times
- Smoke issues from 2409's chimney, seen from the footplate of 5918
- steam_safari_2409_IMG_4486.JPG (53.22 KiB) Viewed 8356 times
- Splitting logs for the fire
- steam_safari_2409_IMG_4489.JPG (83.67 KiB) Viewed 8356 times
- The moment when the needle hit 50 psi and the compressed air was disconnected. 2409 was now truly in steam without any artificial aids.
- steam_safari_2409_IMG_4498.JPG (48.39 KiB) Viewed 8356 times
- Steam can be seen
- steam_safari_2409_IMG_4502.JPG (58.35 KiB) Viewed 8356 times
- Old fitter William stands proudly in front of 2409
- steam_safari_2409_IMG_4503.JPG (61.78 KiB) Viewed 8356 times
- Something big and powerful is making its way out of the gloom into the floodlit shed...
- steam_safari_2409_IMG_4507.JPG (34.15 KiB) Viewed 8356 times
- What looks like an explosion coming out of the safety valve is just the flare from a roof-mounted floodlight
- steam_safari_2409_IMG_4511.JPG (29.2 KiB) Viewed 8356 times
- James at the regulator as 2409 hauls 3020 into the shed
- steam_safari_2409_IMG_4514.JPG (54.92 KiB) Viewed 8356 times
- steam_safari_2409_IMG_4516.JPG (36.65 KiB) Viewed 8356 times
Re: Kenya Steam Safari Preparations 7: 2409 in steam
Great excitement at the Nairobi steam sheds!
Brilliant. Now come on John and get the cabs cleaned. Use a dwashpowder or paraffin. You have been taught!
