Nathan wrote:FOTR is extremely grateful to Rovos Rail for the use of their locomotive.
Cullinan double-header 12th February 2012
- First train for 2012. Class 24 of FOTR with class 19D of Rovos Rail stand alongside the Hermanstad platform. Passengers enjoy the sight and pose on the engines.
- cullinan with double header. 12 Feb 2012 004.jpg (85.54 KiB) Viewed 1501 times
- Gabor Kovacs sets the class 24's lubricator prior to departure.
- cullinan with double header. 12 Feb 2012 005.jpg (62.18 KiB) Viewed 1501 times
- Standing ready to get the departure signal. FOTR and Rovos Rail locomotives on the first train for the club during 2012 to Cullinan for Valentines Day.
- cullinan with double header. 12 Feb 2012 007.jpg (95.24 KiB) Viewed 1501 times
- Cullinan has not had a double header since a steam safari some years back. Rovos Rail class 19D 3360 and FOTR class 14 3664 Joanna at Cullinan. FOTR is extremely grateful to Rovos Rail for the use of their locomotive.
- cullinan with double header. 12 Feb 2012 009.jpg (88.97 KiB) Viewed 1501 times
- Gabor Kovacs on the class 24 tender, taking water.
- cullinan with double header. 12 Feb 2012 012.jpg (75.35 KiB) Viewed 1501 times
- Gabor Kovacs and the water column.
- cullinan with double header. 12 Feb 2012 015.jpg (44.84 KiB) Viewed 1501 times
- Hot work on a steam locomotive. Gabor gets a wash.
- cullinan with double header. 12 Feb 2012 017.jpg (77.38 KiB) Viewed 1501 times
- Peter Odell, an ex Beaconsfield driver, and his trainee, Jeff, chat to Gabor who is on the top of the 24 class tender.
- cullinan with double header. 12 Feb 2012 020.jpg (38.6 KiB) Viewed 1501 times
- Steam trains certainly have a wide appeal.
- cullinan with double header. 12 Feb 2012 022.jpg (85.61 KiB) Viewed 1501 times
- Viewed from the footplate of the class 24, the winding tower headgear for the diamond mine at Cullinan can be clearly seen in the background, as the double header lifts the load out Cullinan back to Pretoria.
- cullinan with double header. 12 Feb 2012 027.jpg (68 KiB) Viewed 1501 times
- Rayton station make a nice setting for this picture.
- cullinan with double header. 12 Feb 2012 029.jpg (96.83 KiB) Viewed 1501 times
- Panpoort ,Oh, Panpoort. Signal check and a lengthy wait for the Pilot working to accept the train.
- cullinan with double header. 12 Feb 2012 033.jpg (107.72 KiB) Viewed 1501 times
- Once the gateway to the Panpoort railway communities' houses, when that station was manned. Perhaps small children would stand here and watch the passing steam parade.
- cullinan with double header. 12 Feb 2012 034.jpg (161.83 KiB) Viewed 1501 times
- Gabor Kovacs
- Friends of The Rail
Re: Cullinan double-header 12th February 2012
Henry Lazenby also recorded some video footage, where I was trainee driver on the lead locomotive, FotR's Class 24 - No 3664. To see video click these links, here
1st sequence - leaving Cullinan, on the southern side of the level crossing to the start of the "Cullinan cutting".
and here;
2nd sequence - leaving the "Cullinan cutting" and heading towards the old abattoir site.
and finally here;
Last sequence - negotiating the hourseshoe curve through Rayton, towards Rayton station.
Thanks goes to Henry for the video footage . . . . :)
and here;
and finally here;
